Manufacturing Solutions
Component Display
Component Display
Component Display
The graphics engine treats each component as an independent unit.  This feature allows you to assign a set of display attributes to each component of your model that determines how each component is displayed.  The display attributes that you can assign to each component are:
Icon
Title
vis01
Wireframe
Element edges display with lines.
vis02
Hidden Line
The element displays as a filled polygon.
vis03
Hidden Line with Mesh Lines
The element displays as a filled polygon with the edges drawn in mesh line color.
vis06
Hidden Line with Feature Lines
The element displays as a filled polygon with the "feature" edges drawn in mesh line color.
vis05
Transparent
The element displays as a filled transparent polygon.
Display attributes can be applied to all components by using the wireframe elements and shaded elements toolbar buttons.  They can be applied to individual components or sets of components through the Visual Attributes panel.  Access this panel by opening View > FE Styles.
See also
User Features of the Graphics Engine
Entity Selection.
Pull down menus
Input Controls
