Manufacturing Solutions
BC Submenu
BC Submenu
BC Submenu
The BC submenu contains the following macros:
bc_menu
BC
Set Injection Locations
Opens the Create Injection Location BC dialog, where you can set up an injection location boundary condition in a specified load collector.
Set Coolant Inlets
Opens the Create Coolant Inlet BC dialog, where you can create a coolant inlet boundary condition in a specified load collector.
<<<Back
Opens the main Moldflow Utility menu.
See Also:
Moldflow Utility Menu
