Existing Slides
Add existing slides from the master Presentation document to the report.
  1. From the Report ribbon, Add Item tool group, click Slides from Existing Slides.
    Or
    Right-click at the report level and select Add > Slides from Existing Slides > Slides.
    The selected slide is added to the tree. If any report item is present in the slide, the associated placeholders and respective properties are listed in the property area.
  2. If a Presentation master is imported and does not contain existing slides, the menu lists No slides found.
