Remove Cuts
Use the Defeature: Cuts tool to extend surface edges and remove cutouts.
View new features for HyperWorks 2021.
Set up your sessions in HyperWorks and create report templates.
Explore the tools used to create geometry.
Explore the tools used to edit geometry.
Clean up problematic areas on geometry.
Use the Defeature tool to automatically find, review, and defeature holes and other non-essential features.
Use the Defeature: Small Features tool to find and remove/fix small solids and surfaces.
Use the Defeature: Logos tool to find and remove logos.
Use the Defeature: Fillets tool to find and remove both round (convex) and fillet (concave) surfaces.
Use the Defeature: Holes tool to remove solid holes in the model.
Use the Defeature: Batch tool to perform automatic cleanup operations on selected surfaces.
Use the Preserve Edges tool to ensure that specific component edges and feature lines do not accidentally get discarded during auto cleanup or batch meshing.
Fix gaps between stitched edges and vertices to make the actual geometry of the surfaces consistent with the model topology.
Find intersections and penetrations between geometric surfaces and solids.
Rapidly change the shape of the FE mesh without severely sacrificing the mesh quality and create, edit, and apply shapes for subsequent design optimization studies.
HyperMesh composites modelings.
The Design Space environment is dedicated to topology optimization model build and setup. It facilitates rapid model creation by generating the voxel design space for a number of different use cases.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to be compatible with this release.
Use the marine tool set to streamline the creation of properties and 1D stiffener mesh using the info read from Marine CAD tools.
Use Squeak and Rattle Director tool set to create evaluation lines, evaluate them and optimize the interfaces to eliminate squeak and rattle issues.
ON THIS PAGE
ON THIS PAGE
