Visualize Modal Deformation, Stress, or Strain Contours
  1. Click on the Contour button on the Result toolbar to display the Contour panel.
  2. Select the appropriate Result type and the direction using the drop-down menus.
  3. Click Apply.
    Note: The Stress or Strain results in the flexible body will be available if Stress or Strain was requested while generating the flexible body.
