Using User-Defined Properties for an Output
If desired, define the output using the User-Defined tab (which will allow you to specify the properties of the output using user subroutines).
  1. From the Result Type drop-down menu, select User Defined.
  2. Define the user subroutine.
    1. Enter the user subroutine function expression in the in the User expr: text box.
    2. Activate the Use local file and function name check box if the use of a local subroutine file is necessary.
    3. Select the subroutine file in the local system by clicking on the Local File: folder icon .
    4. From the Function Type drop-down menu, select the type of the subroutine file: DLL/SO, Python, or MATLAB.
    5. Enter the function name in the Function Name: text box.
      MotionView provides REQSUB as the default, which is the default function used by MotionSolve and ADAMS.
