Animate Flexible Body Results and View Contours in HyperView
  1. Click the Open Model button on the Standard toolbar, or from the File menu select Open > Model.
    See Opening Files in HWD for additional information.
  2. From the Load Model panel, verify that the Load model and Load results check boxes are activated.
  3. Click the Load model file browser .
    The Load Model File dialog is displayed.
  4. Open the ALTAIR.flx file.
    The same file is automatically loaded into the Load results field.
  5. Click Apply.
  6. Click the Start/Pause button on the Animation toolbar to animate the results.
  7. Click the Contour panel button located on the Results toolbar.
    The Contour panel is displayed.
  8. Use the Contour panel to view displacement or stress contours on the model.
