Drum Road
The Drum Road provides the means for you to simulate a tire on a drum, without having to create and position a rotating body for the drum in the MBS model. Drums, typically, are employed to test a tire’s response to being deflected by cleats whose height are much smaller than the tire’s unloaded radius. Typically, there is a mechanism to control the tire’s vertical load, inclination angle, and steer angle relative to the drum. The wheel and tire may be allowed to roll freely on the drum or wheel’s rotational speed may be controlled.
Typical inputs for modeling a Drum Road are the drum’s dimensions (diameter and length), the drum’s position and orientation relative to the wheel center, the number of cleats, their position and orientation on the drum, and their shape, and finally the drum’s rotational speed. Here, however, the drum’s diameter is inferred from the drum surface profile.
The drum surface profile may be specified in a table or read from .csv file. In either case the first column of the table or .csv file gives the distance along the circumference of the drum and the second column gives the drum height. The first distance value must be zero and last distance value gives the circumference of the drum. Hence the drum diameter is last distance value divided by PI. The drum height is linearly interpolated with respect to circumferential distance.
When using the Drum Road, the vehicle or wheel/tire riding on the drum should have no or limited motion relative to the drum to prevent the vehicle or wheel/tire from falling off the drum. There is no check for alerting you about the movement of vehicle away from the drum. However, if at the beginning the vehicle is outside the drum’s x range it will fall to the bottom of the drum. The drum’s width is infinite during simulation (even if the drum graphics are finite).
Vehicle Model Requirements
The steering wheel joint must be locked as it should not induce any steering.
The vehicle should not have longitudinal motion. There is no check for alerting you about the movement of vehicle away from the drum. However if at the beginning the vehicle is outside the drum’s x range it will fall to the bottom of the drum. The drum’s width is considered to be infinite by the solver.
A joint allowing the vehicle to pitch, roll, yaw translate along vertical direction should be available.
Property File
The drum road property file format is similar to other TeimOrbit format 2D road property files consisting of HEADER, UNITS, MODEL, PARAMETERS and GRAPHICS blocks. The HEADER and UNITS blocks are documented here.
Selecting a Drum Road
The model block determines what kind of road the file specifies and in the case of a drum road also selects how the drum profile and drum velocity are specified. To specify a drum road, set METHOD and ROAD_TYPE as shown below:
Parameter Type Valid Values Description
METHOD string '2D' Selects the family of two-dimensional roads.
TYPE string 'DRUM_PROFILE' Selects a drum road.
DRUM_SPEC string 'TABLE' or 'filename' Set DRUM_SPEC = ‘TABLE’ to give the drum surface profile in a table in the [PARAMETERS] block.
Set DRUM_SPEC to a file to read the drum surface profile from a .csv file. For example:
DRUM_SPEC = ‘..\roadProperties\drumProfile_2.csv’
See Specifying the Drum Profile below.
DRUM_VELOCITY string 'TABLE' or 'filename' Set DRUM_VELOCITY = ‘TABLE’ to give the drum surface velocity in a table in the [PARAMETERS] block.
Set DRUM_VELOICTY to a file name to read the drum surface profile from a .csv file. For example:
DRUM_VELOCITY = ‘..\roadProperties\drumVel_2.csv’
See Specifying the Drum Surface Velocity below.
Example MODEL block
$------------------------------MODEL
[MODEL]
 METHOD             = '2D'
 ROAD_TYPE          = 'DRUM_PROFILE'
 DRUM_SPEC          = ‘TABLE’
You specify the drum profile as the incremental height (h) above the nominal drum radius verses distance travelled along the drum circumference. The first value of distance must be 0.0 and the last value of distance determines the drum circumference. The drum heights may be either positive or negative. Negative values are depressions in the drum.
You specify the drum profile either in a table in the PARAMETERS block of property file or in a comma separated values (.csv) file that you reference from the property file.
Table
To specify the drum profile using a table in the PARAMETERS block set DRUM_SPEC = ‘TABLE’ in the [MODEL] block, for example:
[MODEL]
  DRUM_SPEC = ‘TABLE’
[PARAMETERS]
(DRUM_PROFILE)
{distance height}
  0000.0, 0
  1000.0, 0
  1050.0, 50
  1100.0, 0
  3000.0, 0
  3050.0, -50
  3010.0, 0
  4000.0, 0
  5000.0, 0
File
To specify the drum profile using a comma separated values file, set DRUM_SPEC = ‘filename’, for example:
[MODEL]
  DRUM_SPEC = '..\RoadFiles\drumProfile.csv'
You can specify the file using either absolute path or a path relative to the road property file. The first row of .csv file must contain column heading of ‘distance’ and ‘height’ with the subsequent rows containing values for the drum profile. The first distance value must be zero (0.0) and the last value gives the drum circumference. For example:
distance, height
0.0, 0.0
1.0, 0.0
2.0, 0.1
3.0, 0.1
4.0, 0.2
You specify the drum surface velocity (not drum rotational velocity) as a time-velocity table. Values of time in the table or file must be monotonically increasing, and velocity is linearly interpolated with time. For values of time greater than the last value in the table, the last value of velocity is used. For values of time less than the first value in the table, zero is taken.
You can specify the drum velocity either in a table in the PARAMETERS block of property file or in a comma separated values (.csv) file that you reference from the property file.
Table
To specify the drum profile velocity in a table:
[MODEL]
[PARAMETERS]
(TV_TABLE)
{ TIME, VEL }
0.0  1.0
0.2  1.0
File
To specify drum surface velocity in a .csv file in the MODEL block set DRUM_VELOCITY to a filename:
[MODEL]
  DRUM_VELOCITY = '..\RoadFiles\velocityInput.csv'
You can specify the file using either absolute path or a path relative to the road property file. The first row of .csv file must contain column headings of ‘time’ and ‘vel’ with the subsequent rows containing values for the drum velocity. For example:
time, vel
0.0, 10.0
1.0, 10.0
2.0, 10.1
3.0, 11.0
4.0, 12.0
Specifying Drum Graphics Parameters
The drum’s graphics require the input of drum width and spacing between subsequent nodes for creating mesh. Width is only for providing a reasonable drum size. However, the solver code considers the drum to be infinitely wide.
[GRAPHICS]
  WIDTH     = 500  $ width of drum for graphics
  ROAD_INCR = 50   $ distance between two nodes along the surface
