Rapidly change the shape of the FE mesh without severely sacrificing the mesh quality and create, edit, and apply
shapes for subsequent design optimization studies.
The Design Space environment is dedicated to topology optimization model build and setup. It facilitates rapid model creation by generating
the voxel design space for a number of different use cases.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to
be compatible with this release.
Create and edit user-defined data type expressions, derived load cases, and systems. You can also plot a forming limit
diagram, generate streamlines, track entities during animation, and create and import/export sets of entities.
Query entities, create or edit free body diagrams, construct multiple curves and plots from a single result file, and
create and plot stress linearization.
The Vehicle Safety Tools preference file contains templates to plot IIHS front intrusion and IIHS side structure intrusion
plots for Radioss and LS-DYNA files.
The Compare Time History diagnostic tool consists of two pages. On the first page, the input data files, such as plot,
result, and FE files, are selected. Page two contains the data needed to compare the reference files and comparison
files.
Allows you to transform vector results from a time history or animation result files according to a coordinate system
defined by three nodes from the same result file.
The MPDB tool offers a complete automated post processing solution of the MPDB Frontal Compatibility Assessment load case,
for Radioss and LS-DYNA output files.
files.
From the first Compare Time History page, select all reference files and
comparison files.
Click Load.
Page 2 is displayed after the files are loaded into their respective
client windows.
Select the required Result Type.
Select the items in the Result Request list box.
Select the Result Component.
Right-click in the Result Request list box.
If you want to compare selected y-requests for At max Value or Every
Time Step, click accordingly.
Click Isolate to isolate selected requests from list box
in HyperGraph, HyperView
and HyperMesh, depending on the options highlighted
for graphics display.
Click Show in HyperMesh for
selected requests from the list box in HyperGraph,
HyperView and HyperMesh, entities can be seen depending on the buttons
clicked for graphics display.
Click Hide to hide selected requests from list box in
HyperGraph, HyperView and HyperMesh, depending on the buttons clicked
