Create Shape Inputs
Use the Shape tool to create shape design variables based on selected shapes.
From the Design Explorer ribbon, click the Shape
tool.
Select shapes in the following ways:
- On the guide bar, click
. In the Advanced Selection dialog, select a shape then click OK.
- If shapes are turned on in the model, select a shape from the modeling window
Input design variables are created upon selection.By default, a shape variable's upper and lower bounds are chosen as 1.0 and -1.0 respectively. These can be modified in the Inputs review dialog or from the Entity Editor.
