View new features for HyperWorks 2021.
The following file types can be read, depending upon the active application.
Create a new file.
Open a file.
Import various file types into the selected client.
When loading an .hm file, you may receive a warning message depending on the version and solver interface in which the file was last saved.
Load a different solver interface in HyperWorks.
Convert model files from one solver format to another.
Batch mode conversion is available for all solver interfaces.
The OptiStruct to Abaqus conversion uses an open conversion scheme; you can specify different mappings in the configuration file.
Load command files, scripts, solver template files, preferences, or the Metadata Table.
Save all of the data in your current session.
Export various file types from the selected client to another format.
Most FEA solvers allow you to organize the input deck into separate files and provide a mechanism to include (or refer) these files in the main input deck.
Record a video or take a snapshot of the screen.
Set up your sessions in HyperWorks and create report templates.
Rapidly change the shape of the FE mesh without severely sacrificing the mesh quality and create, edit, and apply shapes for subsequent design optimization studies.
HyperMesh composites modelings.
The Design Space environment is dedicated to topology optimization model build and setup. It facilitates rapid model creation by generating the voxel design space for a number of different use cases.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to be compatible with this release.
Use the marine tool set to streamline the creation of properties and 1D stiffener mesh using the info read from Marine CAD tools.
Use Squeak and Rattle Director tool set to create evaluation lines, evaluate them and optimize the interfaces to eliminate squeak and rattle issues.
ON THIS PAGE
ON THIS PAGE
