Use the Split: Interactive tool to quickly create fixed points on surfaces and edges, and split surfaces with lines. You can also remove fixed
points from surfaces or surface edges to unsplit them.
Rapidly change the shape of the FE mesh without severely sacrificing the mesh quality and create, edit, and apply
shapes for subsequent design optimization studies.
The Design Space environment is dedicated to topology optimization model build and setup. It facilitates rapid model creation by generating
the voxel design space for a number of different use cases.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to
be compatible with this release.
Use the Split tools to create fixed points and split
surfaces or solids using a variety of methods.
Split Interactive
Use the Split: Interactive tool to quickly create fixed points on surfaces and edges, and split surfaces with lines. You can also remove fixed points from surfaces or surface edges to unsplit them.
Split with Nodes
Use the Split: Nodes tool to split surfaces using ordered (node list/path) and non-ordered nodes selections.
Split with Lines
Use the Split: Lines tool to split surfaces and solids using lines, bounding lines, offset lines, and graphical lines.
Split with Surfaces
Use the Split: Surfaces tool to split surfaces and solids using surfaces.
Split with Planes
Use the Split: Planes tool to split lines, surfaces, or solids.
