Entity Selector
Entity selectors allow you to indicate which entities are to be modified when a function is performed.
To change the data type, click the entity selector switch to access the pop-up menu of possible data types and select the type you want to use.
In addition to selecting one entity at a time on the screen, you can select multiple entities via quick window selection (hold down the Shift key and drag your mouse to create a window).
These selection options display for all of the entity types supported in the active client. Selections that are not valid for the current entity type are grayed out.
If you want to reset the entity selections, click the reset button to deselect all selected entities.
If the data type is a line list, click the data type of the entity selector to see the selected entities in the order in which they were selected.
- by list
- Allows you to pick the nodes individually from the node list.
- by path
- Allows you to select a few nodes that form a path, which will be used to automatically select all the displayed nodes that lie in the shortest path of the nodes selected. If you select nodes on the edges of a part, the function tries to find the closest path along the edges of that part. By path follows the connectivity of the elements between the nodes selected. Therefore, if the nodes selected are not connected by elements, this function does not apply.
- show node order
- Allows you to view the nodes currently stored in the nodelist collector by numbering the nodes in the sequence of their selection.
- by window
- Allows you to select nodes by window and internally the order of the nodes selected is determined based on its spatial location and element connectivity (if connecting elements exist).
- by list
- Allows you to select lines or surface edges individually in the desired sequence.
- by path
- Allows you to pick surface edges (two or more) and selects all the surface edges that fall in the closest path connecting the selected edges. If you select two free (red) edges, the function tries to find the closest path along the free surface edges. Since this function uses the connectivity of the surfaces, it only works with surface edges and not with free unconnected geometric lines.
Extended Entity Selection Menu
The extended entity selection menu provides a number of entity selection options.
Card Filter
Use the Card Filter to restrict the list of entities displayed when you click the entity selector.
Some panels present a list of entities when you click their Entity Selector button instead of the Extended Entity Selection options.
Assembly | Beamsection collector | Blocks |
Component | Contact surfaces | Control volume |
Curves | Ddvals | Groups |
Laminates | Load collector | Load steps |
Material | Multibodies | Plies |
Plots | Property | Sensors |
Sets | Shapes | System collector |
Tags | Titles | Vector collector |
This displays a read-only text field adjacent to the Card Filter control. Click card to open a pop-up window that lists all of the cards defined in your model for the selected type of entity, and pick the card that you wish to filter by.
Once selected, only entities with the chosen card type will display in the entity list on the panel.
To remove the filter, simply use the switch to select all, displaying all entities regardless of card association, or no card, displaying only those entities that do not have a card at all.
Select Nodes on Geometry or Elements
Node and node list entity selectors allow you to not only select existing nodes in the model, they also allow you to create new nodes on geometry or on elements.
You can create a node on geometry by holding the left mouse button down along the geometry handle until the cursor becomes a square and then selecting the geometry (lines, edges, surfaces) on which you would like to place a node. Then, move your cursor to the exact location on the geometry where you would like the node to be placed and click the left mouse button to place a node. You can create nodes on elements by holding the left mouse button down on an element handle until the cursor becomes a square and selecting the element. Then, move the cursor to the exact location on the elements of that component and click the left mouse button to place the node.
Select new nodes on geometry.
Select new nodes on elements.
Select Entities in the Modeling Window
After you select the correct data type, you can use the mouse to select the desired entities in the modeling window.
The graphics engine allows you to select entities by moving the mouse anywhere along the entity of interest. For lines and surfaces, it is much easier to work when you are zoomed in on a particular area, as you are not required to have a pick handle on the screen in order to pick the entity.
Another key feature in the graphics engine is the method by which nodes are selected. To select a node, select the element to which the node of interest is attached. HyperWorks Desktop selects the node closest to the point where the element was selected. The benefit of this feature is that it allows you to create zero length elements between two coincident nodes in a mesh.
For nodes that are not attached to any elements, HyperWorks Desktop allows you to select the node by picking the "node sphere" on the screen.
Each type of entity has a pick handle that allows you to select the entity.
Entity | Pick Handle | ||
Nodes | The pick handle for a node is located at the node. To select a node, move the mouse to the location on the screen where the node resides. If you need to select nodes on geometry or on an element where nodes do not currently exist. | ||
Elements | Shell and solid element pick handles are displayed as
pixels at the centroid of the element. 1D element pick
handles are displayed as letters at the centroid of the
elements:
Click the Display Element Handles icon on the Display toolbar to switch the display of element handles on or off. Element handles can be selected whether or not they are displayed. |
Lines | Each segment of a line has pick handles along its length.
Each pick handle is displayed as a small "+." If there are
many pick handles, a "+" is displayed at only some of the
pick handles. Click the Display Element Handles button on the Display toolbar to switch the display of element handles on or off. |
Surfaces | Surfaces do not have pick handles. Surfaces can be selected along their edges or on interior UV lines, also known as surface lines. | ||
Components | Components do not have pick handles. A component can be selected by picking an element, line, or surface within that component. | ||
Systems | The pick handle for a coordinate system is located at the origin of the system. | ||
System Collectors | System collectors do not have pick handles. To select a system collector, simply select a system within that system collector. | ||
Loads | The pick handle for a load is located at the pick handle of the entity to which the load is applied. | ||
Load Collectors | Load collectors do not have pick handles. To select a load collector, simply select a load within that system collector. | ||
Plots | A plot can be selected by picking within its border. | ||
Blocks | Blocks do not have pick handles. Blocks are drawn in shaded mode with transparency and can be selected by picking anywhere on the entity. | ||
Titles | A title can be selected by picking within its bounding box. | ||
Vectors | Vector pick handles are located at the arrow tip of the vector. | ||
Curves | A curve can be selected by clicking anywhere along the curve. |
User Features of the Graphics Engine
When you are post-processing, the graphics engine offers advanced and powerful features.
- Cutting plane
- Cutting plane functions have been expanded to allow three planes to be active simultaneously. Cutting plane control is more interactive and is controlled by selecting any of the active planes with the mouse and then dragging the plane across the model. The cutting plane feature can be found in the Hidden Line, Contour, and Animation panels.
- Isosurfaces
- The isosurfaces subpanel is available on the Contour and Animation panels. Isosurfaces can be displayed on a model in either a legend-based mode in which each of the legend colors generates an isosurface, or as a value-based surface in which you specify a value that indicates where an isosurface should be displayed.
- Hidden components
- If one or more of the components in a model are set to a display style besides wireframe, then HyperWorks Desktop draws the whole model in hidden line. To perform this task, HyperWorks Desktop relies on the z-buffer found on your graphics device. The z-buffer allows HyperWorks Desktop to render your model in hidden line, with the elements in back eliminated from the display. There are some limitations to using a z-buffer and some display output differences of which you should be aware.
- Optimization
- The graphics engine optimizes the display of your finite element model. One of the optimizations is the removal of interior solid faces. If you have solid elements in your model, HyperWorks Desktop calculates where the external faces are in your model, and displays these instead of displaying all of the faces.
- Memory usage
- HyperWorks Desktop graphics use some memory. If swapping occurs while you are running HyperWorks Desktop, this could seriously affect performance. If you encounter this problem, you should obtain more system memory.
