Change the Display Options
In the Set panel, use the following options to change the display of the selected entities in a set.
  1. From the Visualization toolbar, click Sets .
  2. From the Set panel, select a set/group.
  3. Activate the Show ID check box to display the IDs of the selected entities in a set.
  4. Click the Color box to change the color of the feature lines of the selected entities in a set.
  5. Use the Draw style options to select the drawing style for the active set.
    Option Description
    shaded Shades the components in the active set the color currently displayed in the Color box.
    If a contour is applied, the components in the set will display their contour color instead of the selected shaded color.
    Note: Available for Component sets only.
    wire Draws a wireframe on the elements or components in the active set.
    Note: Available for Component or Element sets only.
    point Draws the nodes in the set using 2D pixels.
    Note: Available for Node sets only.
    sphere Draws the nodes in the set using 3D pixels.
  6. Enter a Draw size value to change the thickness of the wire or the size of the point/sphere drawing for the active set.
