Sort Midsurfaces
Manually sort midsurfaces after extraction.
  1. From the Geom page, select the midsurface panel.
  2. Select sort.
  3. Select a method for sorting midsurfaces.
    • Choose <~[o]riginal name> comp to create new components by removing the first letter of the original component name and replacing it with a ~ and sorts the midsurfaces accordingly. For example, my_comp -> ~y_comp.
    • Choose <Midsurface #nn> comp to create components with the name Midsurface #, where # increases for each component that exists for the input surfaces/solids.
    • Choose original comp to organize the midsurfaces into their parent surface/solid components.
    • Choose <original name~> comp to create components using the original component name and adds ~ at the end.
    • Choose <original nameN> comp to create new components by incrementing the name of the original.
  4. Click sort.
