Creo Reader
Supported Entities
Entities supported by the Creo reader.
  • Free points
  • Free curves
  • Surfaces
  • Quilt bodies
  • Solid bodies
  • Coordinate systems
  • Assemblies
  • Assembly Level Features are currently not supported.
  • Family Tables are currently not supported.
Entities with non-latin characters in their names are supported.
Import Options
The Creo reader uses the ct_reader.ini file.
@AttributesAsMetadata
Value Description
on
Import all generic attributes (global and related to single entities) as metadata.
off Do not import attributes related to single entities. Only import global attributes.
%attribute1%attribute2%attribute3
Import specified generic attributes as metadata.
The attribute names are listed, separated by a character that you choose, and inserted as the first element of the string. The example uses '%' as a separator. You can choose another character as a separator, in case one of the listed attribute names contains '%'. HyperMesh will recognize it as it is the first character of the string.
@AvoidThirdPartyConversion
Value Description
on Avoid using the conversion functions provided by third-party (default).
off Use the conversion functions provided by third-party.
@BodyIdAsMetadata
Value Description
on Assign body identifier as metadata.
BODY_ID
off Do not assign body identifier as metadata (default).
@CleanupTol
Value Description
double A negative value (default) indicates to use the auto cleanup tolerance. A value greater than the calculated auto cleanup tolerance indicates to use that specific tolerance. Refer to the CAD Cleanup Tolerance.
@ColorsAsMetadata
Value Description
on
Read color attributes of geometric entities as metadata.
COLOR_RGB
off Do not read color attributes (default).
@CreationType
Value Description
Parts Generate a full part-based hierarchy.
BOMOnly Generate an empty part-based hierarchy.
TreeOfComponents Generate an assemblies/components based hierarchy.
PackIntoSinglePart Consolidate hierarchy into a single part.
@DensityAsMetadata
Value Description
on
Read density value as metadata (default).
DENSITY
off Do not read density value.
@DoNotMergeEdges
Value Description
on Preserve the original geometry edges, instead of merging them together during the import cleanup phase.
off Merge edges together during the import cleanup phase (default).
@FullNameAsMetadata
Value Description
on
Generate the full CAD name, as retrieved from the CAD part, as metadata. This consists of assembly name/part name/feature name/entity name.
FULL_IDENTIFIER
off Do not generate full name metadata (default).
@ImportBlanked
Value Description
on Import entities that are hidden, blanked, or no show.
off Do not import entities that are hidden, blanked, or no show (default).
@ImportCoordinateSystems
Value Description
on Import CAD coordinate systems as system collectors (default).
off Do not import CAD coordinate systems.
@ImportForVisualizationOnly
Value Description
on
Import the model for visualization purposes only.
This skips many of the import steps (cleanup, stitching, solid creation, and so on) to provide a faster import. The resulting model may not be suitable for other uses.
off Import the model in the normal fashion (default).
@ImportFreeCurves
Value Description
on Import free curves (wireframe entities) into the model (default).
off Do not import free curves.
@ImportFreePoints
Value Description
on Import free points into the model (default).
off Do not import free points.
@LayerAsMetadata
Value Description
on Read layer value as metadata.
LAYER
off Do not read layer value (default).
@LegacyHierarchyAsMetadata
Value Description
on Generate metadata with the original CAD hierarchy within the part.
LEGACY_HIERARCHY
off Do not generate metadata with the original CAD hierarchy within the part (default).
@MaterialName
Value Description
string Name of the CAD attribute containing the PDM material name info of the current part.
Default is "Material".
@MeshFlag
Value Description
string Name of the CAD attribute containing the PDM mesh flag name info of the current part.
Default is "MeshFlag".
@MetadataPrefix
Value Description
string The string is prefixed to all metadata names. No prefix is used by default.
See CAD Metadata Naming for more details.
@MID
Value Description
string Name of the CAD attribute containing the PDM material ID info of the current part.
Default is "MID".
@OriginalIdAsMetadata
Value Description
on Import original CAD entity IDs as metadata.
ORIGINAL_ID
off Do not import original CAD entity IDs as metadata (default).
@PartNumber
Value Description
string Name of the CAD attribute containing the PDM part number info of the current part.
Default is "PartNumber”.
@PID
Value Description
string Name of the CAD attribute containing PDM property ID info of the current part.
Default is "PID”.
@Revision
Value Description
string Name of the CAD attribute containing PDM major revision info of the current part.
Default is "Revision”.
@ScaleFactor
Value Description
double Define the model scaling factor during import.
Default is 1.0.
@ShrinkSurfaces
Value Description
on For trimmed surfaces, shrink the corresponding base surfaces to only enclose the extents of the external trimming contour, plus a narrow frame.
off Do not modify the base surfaces (default).
@SkipCreationOfSolid
Value Description
on Read surfaces, but do not create solid entities.
off Create solid entities (default).
@SplitComponents
Value Description
Body Generate body-based component (default if CreationType=Parts).
Layer Generate layer-based component.
Part Generate part-based component.
General Keep component as in CAD (default if CreationType=TreeOfComponents).
@SplitComponentsByBody
Value Description
on
Create one component per third-party body. There might be one or more third-party bodies per third-party component.
This option cannot be used when @ReadCompositeData is enabled, or in conjunction with @SplitComponentsByPart.
off Do not consider the division of third-party components into third-party bodies while creating components (default).
@StitchingAcrossBodies
Value Description
on Stitch surfaces belonging to different components.
off Do not stitch surfaces belonging to different components (default).
@TagsAsMetadata
Value Description
on
Create entity name as metadata (default).
TAG
FromBody
Take entity from its parent body and create as metadata.
TAG
off Do not read tags.
@TargetUnits
Value Description
CAD units Keep the units of the CAD files (default for GUI).
MKS [m kg N s] Convert to the corresponding units system.
MMKS [mm kg N s] Convert to the corresponding units system.
MPA [mm t N s] Convert to the corresponding units system.
CGS [cm g dyn s] Convert to the corresponding units system.
MMKNMS [mm kg kN ms] Convert to the corresponding units system.
MMGNMS [mm g N ms] Convert to the corresponding units system.
IPS Std [in pounds lbf s] Convert to the corresponding units system.
IPS Grav [in slinch lbf s] Convert to the corresponding units system.
FPS Std [ft pounds lbf s] Convert to the corresponding units system.
FPS Grav [ft slug lbf s] Convert to the corresponding units system.
Scale factor Apply the corresponding scale factor (default for no GUI to allow supporting legacy scripts).
@ThicknessName
Value Description
string Name of the CAD attribute containing the PDM thickness info of the current part.
Default is "Thickness".
@UID
Value Description
string Name of the CAD attribute containing the PDM UID info of the current part.
Default is "UID".
Supported Metadata
Metadata generated from the Creo reader.
BODY_ID
Type Entities Description
string
  • points
  • lines
  • surfs
Identifier of the CAD body containing the entity.
Generated when @BodyIDAsMetadata=on
COLOR_RGB
string comps, assems if hierarchy as Assemblies; parts if hierarchy as Parts
Three RGB values, ranging from 0 to 255, indicating the color of the entity in the CAD model.
Generated when @ColorsAsMetadata = on
DENSITY
double solids
The value of the density of a solid.
Generated when @DensityAsMetadata = on
FULL_IDENTIFIER
string
points
lines
surfs
solids
comps
assems
A string indicating the name in the following format:
"part_name/name"
Generated when @FullNameAsMetadata = on
LAYER
integer
  • points
  • lines
  • surfs
  • solids
Value of the layer of an entity.
Generated when @LayerAsMetadata=on
LEGACY_HIERARCHY
string
  • points
  • lines
  • surfs
Hierarchy of an entity within a part.
Generated when @LegacyHierarchyAsMetadata=on
MODELUNIT
integer comps if hierarchy as Assemblies; parts if hierarchy as Parts Model units specified in the CAD file.
  • 1 = inches
  • 2 = millimeters
  • 4 = feet
  • 5 = miles
  • 6 = meters
  • 7 = kilometers
  • 8 = mils
  • 9 = microns
  • 10 = centimeters
  • 11 = microinches
  • 12 = decimeters
  • 13 = yards
This is always generated.
ORIGINAL_ID
string
points
lines
edges
surfs
solids
parts
The original CAD entity ID.
Generated when @OriginalIdAsMetadata = on
TAG
string
points
lines
edges
surfs
solids
The tag (name) of the entity as read from the CAD model, if one exists.
Generated when @TagsAsMetadata = on
