Color Band Generation
A contour plot generates color bands on the model, based on the values found in the results file.
HyperLife processes these values as described below:
Nodal results
Nodal results such as temperature, displacement, velocity or acceleration are stored at the nodes. Colors are displayed at the nodes using nodal values directly or transformed values using the system selected for Resolved in.
Element results
The values can be located at the element centroidal or corners. The Use corner data option is available when a result file contains corner results. You can display the results at the elements directly without using an averaging method, or average them to nodes using the simple or advanced averaging method. The calculated values shown in the legend may vary due to the different averaging methods.
Centroidal results A solid color is displayed at the elements using the elemental centroidal results directly.
Corner results The values are located at the corners of an element. Discontinuous color bands are displayed within each element using corner results.
None When no averaging method is used, the results remain as element binding, so you can query results using the Elements option in the Query panel or Measure panel.
Simple averaging
HyperLife averages the results to the nodes based on a user-specified variation percentage. If the Variation (%) option is not used, HyperLife simply averages the elemental values to nodes and the calculated results can be queried at nodes. If Variation (%) is enabled, HyperLife averages elemental values to the nodes at the areas where the variation is less than the specified percentage and leaves other areas as they are without averaging. In this case, HyperLife represents results in element binding, so you can query results using the Elements input collector on the Query panel. When entering the Query panel, you can see the contour values are displayed as available elemental items. See the Variation Percentage Control topic for further explanation.
Advanced averaging
Advanced averaging is similar to simple averaging. Without using variation, HyperLife averages elemental values to all nodes. The calculated nodal results can be queried using the Nodes input collector on the Query panel. When using variation, the results remain as element bound and are queried using the Elements input collector.
Difference
HyperLife calculates the difference of corner or centroidal results and assigns it to a node. You can query results using the Nodes input collector on the Query panel.
Modal animation
  • The Complex filter options allow you to extract one of the components from a complex number such as mag, phase, real, or imaginary separately.
  • HyperLife automatically recognizes a subcase with complex results and loads the model and results in the modal mode.
  • Complex filter is activated when a complex result type is selected. It is only applied to result types that are provided directly from solvers such as Displacements X, Y, Z or Stress Sxx, Syy, Szz, etc. This filter is not applicable to derived results such as Displacement magnitude or vonMises.
  • If you measure contour nodal results as a complex number using mag cos(wt-phase), a sinusoidal (Cosine) curve with phase shift is calculated.
  • If you measure any of the components of a complex number (mag, phase, real or imaginary), the curve is shown as constant.
Transient mode
HyperLife will use the Mag across all the frequencies. This will be useful to examine the peak across all the frequencies. Essentially, the curve created from measure should agree with the curve of magnitude you get from the PCH file in the complex plot.
Envelope loadstep - Contour panel options
An Envelope loadstep (with Min, Max, Extreme, and Range options) is a single simulation step containing results from multiple simulation steps for the model. Result transformations and Averaging options are not available for data contoured from an Envelope loadstep. All results are presented in the Analysis system with no averaging.
