HVVH-6020: Solution Tab - Verify OptiStruct Results with MAC Comparison
Perform a verification based on the Modal Assurance Criterion (MAC) for the OptiStruct solver (NVH).
  1. From the Solution tab, select the Solver version result comparison tab.
  2. From the Solver type list, select OptiStruct.
  3. From the Tolerance list, select the default (1e-06). You can set any tolerance for Scalar, Vector, or Tensor data types.
  4. From the Result list, select H3D.
  5. Under Current, in the Load Model and Load Result fields, click the file browser icon, , to load the NMA_1.h3d file, located in ..\tutorials\hvvh\Solution\ Optistruct\Mac\.
  6. Under Reference, for the Load Model and Load Result fields, click to load the NMA_2.h3d file, located in ..\tutorials\hvvh\Solution\ Optistruct\Mac\.
  7. In the Output directory field, click to select an output directory.
  8. Click the MAC check box.
  9. Click the Mac Only button.
    The mac calculations start and correlation plots and mode pairs bar plot are generated.
    Note: The default config file that contains frequency information and the number of MAC values to calculate is available in the current results directory. For example, NMA_1_mac.cfg. This can be changed for different MAC calculations and comparisons.
  10. Click Apply.
    The results available (subcase, simulation, and result type) in the current result file are loaded in the three windows.
  11. Select All under each of the windows and click the second Apply button.
    Any combination of Subcase, Simulation, and Datatype can be selected for comparison. Comparisons of the current and reference results are generated.
    In the Messages window, the run details and log file location are displayed.
    If the difference is greater than the tolerance, it is indicated with the label Fail; otherwise they are labeled Pass.
  12. Click HTML Report to view the HTML report.
    Comparisons between different data types are available.
  13. From the HTML report, click MAC report to open the correlation plot and mode pair bar plot.
    Figure 3.
    Figure 4.
    Figure 5.
    Figure 6.
  14. Click the first column of the table to open a new modeling window.
    Figure 7.
    In the image above, the left window shows a diff contour (Current-Reference) and the right window shows a diff plot in HyperGraph.
  15. Click the left window to open the diff-values in H3D in HyperView Player.
    You can view the difference in the contour and view the area where there is a difference in case of a failure.
  16. Click the right window to maximize/minimize the plot.
    The difference values for each step are calculated and the min and max values of the difference are plotted. If all the values match and no difference is seen, the curve is a flat line and the diff contours have values less than the tolerance.
  17. From the HTML report, click the link to the MAC report to open the correlation plot and the mode pair bar plot.
    This gives information on the model correlation across two results and the modal pairs with different MAC numbers.
    Mode number, frequency, percent frequency difference, and MAC values are listed in the MAC table.
