Feko is a comprehensive electromagnetic solver with multiple solution methods that is used for electromagnetic field analyses
involving 3D objects of arbitrary shapes.
EDITFEKO is used to construct advanced models (both the geometry and solution requirements) using a high-level scripting language
which includes loops and conditional statements.
Feko offers state-of-the-art optimisation engines based on generic algorithm (GA) and other methods, which can be used
to automatically optimise the design and determine the optimum solution.
CADFEKO and POSTFEKO have a powerful, fast, lightweight scripting language integrated into the application allowing you to create
models, get hold of simulation results and model configuration information as well as manipulation of data and automate
repetitive tasks.
CADFEKO and POSTFEKO have a powerful, fast, lightweight scripting language integrated into the application that allows you to create models,
get hold of simulation results and model configuration information and much more.
Feko integrates into job scheduling and queuing systems such as Altair PBS Professional, Torque, IBM Platform LSF, Parallelnavi NQS, SLURM and Univa Grid Engine.
The MLFMM is an iterative solution method, and under certain conditions, the iterative solution may fail to converge. Several
model or solution settings are presented that could improve the model's convergence behaviour.
The hybrid multilevel fast multipole method (MLFMM) / finite element method (FEM) is an iterative solution method and under certain conditions, the iterative solution may fail to converge.
Several model or solution settings are presented that could improve the model's convergence behaviour.
The hybrid method of moments (MoM) / finite element method (FEM) is an iterative solution method, and under certain conditions, the iterative solution may fail to converge.
The finite difference time domain (FDTD) is a solution method that may fail to converge under certain conditions. Several model or solution settings
When meshing a model, you can either use the automatic meshing algorithm to calculate the appropriate mesh settings
or you can specify the mesh sizes. When you specify the mesh sizes, the mesh sizes should adhere to certain guidelines.
Feko integrates with various products within HyperWorks such as HyperStudy. Integration with third-party products is also supported through the powerful scripting and plug-in infrastructure.
Feko creates and uses many different file types. It is useful to know what is stored in the various files and weather they were
created by Feko and if it is safe to delete them. The files are grouped as either native files that have been created by Feko or non-native files that are supported by Feko. Non-native files are often exported by Feko even if the formats are not under the control of the Feko development team.
A list of notes, errors and warnings are provided as reference and to provide more information regarding the reason for
the message and how to resolve the problem in the model.
Different configurations using a microstrip port are considered.
The first configuration considered is to define a microstrip port on the full width of
the microstrip line. For the second and third configurations, a feed structure is
created using polygons to decrease the width of the microstrip port.
Narrow Version
To decrease the width of the microstrip port, a polygon is added to the microstrip
line to act as the feed structure. For better accuracy, ensure that the width of the
microstrip port is roughly of the microstrip line width.
