Using the Application Macro
Execute the application macro in CADFEKO to transfer user-defined settings to another Feko version.
Open CADFEKO and run the macro.
The Transfer user configurations dialog is shown.
- From the Source list, select the version to copy settings from.
From the Destination list, select the version to copy
settings to.
Note: Only Feko versions installed in the same directory as the current running version, for example, C:/Program Files/Altair, are displayed in the Source and Destination lists.
[Optional] Clear the check boxes for the settings that are not required for
transfer.
Note: If Application Macro Library is selected, the application macro locations are transferred. (The application macro files are not copied to a new location.)
- Click Copy.
Finish the process by clicking OK to acknowledge the
messages.
- If the Destination is the current running
version, a new CADFEKO session is started with
the transferred settings.
After the new session is started, click OK to close the old CADFEKO session.
- If the Destination is not the current running version, click Close to dismiss the Transfer user configurations dialog.
The new settings are now available. - If the Destination is the current running
