Install Additional Python Packages
There are several ways to install additional Python packages.
Use the pip command to install packages from the repository.
  • Run the Python executable:
    Windows
    <INSTALLATION_ROOT>\common\python\python3.5\win64\python.exe ‐m pip install <package>
    Linux
    <INSTALLATION_ROOT>/.altair/common/python/python3.5/linux64/bin/python3 ‐m pip install <package>
  • For both Windows and Linux, you can also install a pre-compiled binary that's downloaded from other sources rather than installing from an online package, which could require compiling from the source. Resolving dependency issues on Windows can be complicated.
  • From the Python packages, download the wheel package and use the following command to install it:
    Windows
    <INSTALLATION_ROOT>\common\python\python3.5\win64\python.exe ‐m pip install <path‐to‐wheel>/package_name.whl
    Linux
    <INSTALLATION_ROOT>/.altair/common/python/python3.5/linux64/bin/python3 ‐m pip install <path‐to‐wheel>/package_name.whl
  • Note: If a Python package requires any direct or indirect building of C++/Fortran code, it may not work.
  • Install a Python package using the “--user” option.
    • Python packages installed using the “--user” option go to a default location if the PYTHONUSERBASE environment variable is not set. Python packages installed for other applications using “--user” will interfere with Compose if PYTHONUSERBASE is not set.
    • To avoid the potential problem, Compose sets PYTHONUSERBASE to:
      <user home directory>/.altair/Compose<version>/hwx/python
    • Set PYTHONUSERBASE to <user home directory>/.altair/ Compose<version>/hwx/python before using the argument “--user” to install packages.
      Windows
      set PYTHONUSERBASE=C:/Users/<userid>/.altair/Compose2021/hwx/python
      <INSTALLATION_ROOT>\common\python\python3.5\win64\python.exe ‐m pip install --user <package>
      Linux
      export PYTHONUSERBASE=/home/<userid>/.altair/Compose2021/hwx/python
      <INSTALLATION_ROOT>/.altair/common/python/python3.5/linux64/bin/python3 ‐m pip install --user <package>
