The Compose Notebook is a web-based implementation of Compose’s OpenMatrix Language (OML) into a Jupyter Notebook. Notebooks (see www.jupyter.org) are a powerful way to execute and demonstrate scripted languages.
Watch Window
Use the Watch window to monitor variable values while stepping through scripts.
Call Stack Window
The Call Stack window displays the paths traced while executing scripts.
Breakpoints Window
The Breakpoints window displays all breakpoints in the debugging session. Each breakpoint is listed along with its host file and the line number.
