Write a Fortran OML Library Using the Binary-compatible Interface
As an extension of the BCI interface exposed above, this topic describes how to turn Fortran code into an OML function.
- Compile the Fortran source code into an object.
Using a Fortran compiler, compile myFortransub.f into myFortransub.o.
- Add the standard C/C++ library OMLInterfacePublic.h to the Project folder.
- Create a C/C++ file according to the Fortran function arguments,
The C/C++ file must contain:
- OML header to be used (OMLInterfacePublic.h).
- Extern āCā block.
- InitToolbox function.
- C/C++ function calling the Fortran function.
- Link the compiled Fortran file to the Project.
- Compile the C/C++ code to create the DLL file (for example, omlFortran.dll).
- To the Project folder, add the Fortran DLL that was called/used upon the Fortran compilation.
- Import the DLL with the addlibrary function.
Example - Fortran Routine Compiled and Added to OML
function myFortranSub(Method,Rs,Rz,RF)
IF (Method == 1) THEN
RF = 1/(Rs+Rz)
ELSE IF (Method == 2) THEN
RF = 1/(Rs**2+Rz**2)**.5
ELSE
RF = 1/(Rs+Rz)
END IF
end function myFortranSub#include "OMLInterfacePublic.h"
extern "C"
__declspec(dllexport) int InitToolbox(OMLInterface* eval);
void __stdcall myfortransub_(int*,float*,float*,float*);
bool myFortranFunc(OMLInterface* eval, const OMLCurrencyList* inputs, OMLCurrencyList* outputs)
if (inputs->Size() != 3)
eval->ThrowError("Wrong number of arguments");
const OMLCurrency* c1 = inputs->Get(0);
const OMLCurrency* c2 = inputs->Get(1);
const OMLCurrency* c3 = inputs->Get(2);
if (!c1->IsScalar())
eval->ThrowError("Invalid input type in argument 1");
if (!c2->IsScalar())
eval->ThrowError("Invalid input type in argument 2");
if (!c3->IsScalar())
eval->ThrowError("Invalid input type in argument 3");
int input1 = (int)c1->GetScalar();
float input2 = (float)c2->GetScalar();
float input3 = (float)c3->GetScalar();
float output1 = 0.0;
myfortransub_(&input1, &input2, &input3, &output1);
outputs->AddScalar(output1);
return true;
eval->RegisterFunction("reservefactor", myFortranFunc);
return 0;
}myfortransub_(&input1, &input2, &input3, &output1);- In Fortran, the Function arguments are all passed by reference.
- Notice the extra underscore character added to the function name.
