Running Compose in GUI (Interactive and Graphic) Mode
GUI mode provides access to all editorial, execution, and management features of the Integrated Development Environment (IDE).
GUI mode can be started from the Start menu, or from a DOS prompt on a PC.
| For this setup | Do the following |
| Windows PC for Compose | From the Start menu, click |
| DOS Prompt |
Run the command <install directory>/Compose.bat This command supports the following optional arguments: Compose.bat -f <file> will execute <file>. Supported extensions are .oml, .py, .tcl, and .r or .R). |
| Linux Shell | Run the command <install directory>/Compose |
