Find
Find objects in the scene that contain the search string you enter. The search results are not filtered.
  1. Press Ctrl+1 to open the Model Browser.
  2. Click to open the Find toolbar.
  3. Optional: To control your search, click , and then click one or more of the following options:
    • Match Case
    • Whole Names Only
    • Use Wildcards
  4. In the text field, type a search string.
The first object that contains the search string is highlighted in the Model Browser.
Find Options
Option Description
Navigate to the next or previous object that contains the search string.
Find every object that contains the search string.
Access additional options to control the search:
  • Match Case
  • Whole Names Only
  • Use Wildcards
