Process Parameters
Use the Process Parameters icon to define the filling, gelling and tilt-pouring processes of the simulation.
Basic
Use the Basic tab to define the conditions for ending a simulation.
Ending Conditions
Parameter | Description |
Filled Volume | End the simulation when the material volume in the mold reaches the specified percentage. |
Gelling Rate | End the simulation when the gelling rate of the material reaches the specified percentage. |
Time | End the simulation when the filling time exceeds the input value. |
Continue to Calculate the reaction after filling | Select this option to continue calculating the foaming reaction after the cavity is filled. |
Advanced
Use the Advanced tab to define tilt-pouring events for a foaming analysis.
Tilt Pouring
Select and manipulate the Move tool to define the mold-tilting location, or enter the X, Y and Z coordinates in the microdialog. | |
Rotation Axis | Select the axis to orient the tilt of the mold. |
Preview | Play an animation of the of the tilt-pouring rotation. |
Time | Enter the start time for each tilt-pouring event. |
Angle | Enter the angle of the tilt relative to the current position of the mold. |
Insert and delete rows in the data table for tilt pouring:
