Edit Data Table Layout
Panopticon Designer (Desktop) lets you quickly connect to any data source and combine data from multiple sources so you can visualize all your data in a single visualization.
Connecting to data environments is easy with pre-built connectors to a wide variety of sources right out of the box.
However, to get the most of these data and produce effective visualizations, they may need to be:
Integrated with other data sources or files to produce a data with more sense
Transformed
For normalization and aggregation.
New columns may also be generated from existing data:
Bucketing
The self-service Edit Data Table layout allows you do all these.
