Open the Move tool to move the selected points, edges, or
faces. |
Make the selected points collinear. |
Only available when you select multiple points. |
Flatten to face. |
Clicking this icon will project the selected face onto the dotted
plane. If two edges are selected, clicking this icon will set the edges
parallel. |
Project the selected point or face to the x-, y-, or z-axis. |
Only available for points and faces. |
Patch across free edges. |
Only available when you have selected a connected set of PolyNURBS
edges. Double-click an edge to quickly select a connected set of
edges. |
