Assign Materials
Assign materials from the Materials Database when designating the mold cavity.
Use the Designate Part Cavity tool or the
Auto Configure Components tool to indentify the part
cavity.
Use the microdialog options to define the material type, polymer and
temperature.
Option Description Note Click the View Materials button to examine a material's thermal, rhealogical, mechanical, PVT and fiber properties.
- You can modify an existing material in the Materials dialog, save it with a new name, and access it from the My Materials tab.
- You can download additional materials from the Altair Material Data Center, save them locally, and import them into the Inspire Mold material database.
Select a material type. Select from common polymers of your chosen material type. Enter the temperature of the material.
