Submitting a Job
Define and run an analyis using the Run Analysis tool.
The model setup should be completed before submitting job for analysis. Save the model in a new folder with the desired project name. Analysis will be performed in this folder based on user preference under Run Options.
Analysis Parameters Settings
- Project Name
- The data deck is written with "name" as a prefix. It is written in the same folder where the model is saved. Avoid using special characters as files will be created using this name.
- Pressure Type
- Preferred option for pressure type is Linear or Mapped.
- Mesh Size
- Medium is the preferred option. If the model has many fine features, selecting fine is recommended. If it is a simple model, coarse option can be used. To start from existing mesh, click on Existing and select the mesh file.
- Mesh Order
- Second order mesh gives more accurate results, but at the cost of computational time. First order mesh is the recommended option.
- Analysis Type
- Elastic Deformation within elastic limit. Reforms to original shape.
