Quench System Database
The quench system database allows you to save created quench systems. You can retrieve the stored quench systems from the database to reuse in future simulations.
![](../../../images/icons/extrude/icon_quench_list.png)
![](../../../images/figures/extrude/quench_system_db.png)
Add a Quench System to Database
To add a quench system to database, quench system setup must be completed. You can add only the current quench system created/modified in that session.
![](../../../images/icons/extrude/icon_plus.png)
![](../../../images/figures/extrude/quench_system_db_02.png)
Delete a Quench System from Database
- Select the quench system to be deleted from the list.
Click on the
icon to delete the selected quench system.
Load a Quench System from Database
![](../../../images/figures/extrude/quench_system.png)
