Add Callouts to the Results
Call out and review values for a selected result type at points of interest on your model using the callout icons in the Analysis Explorer.
- Select the Show Analysis Results tool on the Analyze icon, if not already active.
To create a callout at a point of interest, click
in the Analysis Explorer, select a
Result Type, and then click a point on your model.
Box-select to see the maximum value in an area.
Note: The callout value applies to the currently selected run and load case. -
To automatically create callouts showing where the minimum and maximum values
occur for a result type, select a Result Type, and then
click
Note: When you select Factor of Safety for the result type, the minimum is shown. - Optional:
To display callouts in a table, click
Each callout is specific to a selected run
and load case.
- Selecting a row in the table also selects the callout in the modeling window.
- To show or hide a single callout, in the Callouts table, Name column,
click
. - To show or hide all callouts, in the Analysis Explorer, click
. - To sort the order of a column in the table, click the column header. Or
you can click
or
to select Sort
Ascending or Sort Descending.
- To add or delete columns on the table, right-click a column header, and
then select or deselect a property.
- Optional: For motion part analysis results, click the Plot button to display time history plots for callouts defined for structural analysis. Changes made to the Result Types option are synchronized with the setting on the Analysis Explorer. Using this option allows you to put multiple plots of mixed types on a single page.
