Force Explorer
Use the Force Explorer to visualize force and torque vectors in a motion analysis.
This tool can be accessed by clicking the Run group label on the Motion ribbon.
![](../../../images/figures/inspire/force_explorer_button.png)
Figure 1. Force Explorer
The visualization is available for joints, motors, motion contacts, and other entities during the run or when playing back the results. This is useful for understanding how loads are developing in your mechanisms, as well as presentations and debugging.
Show Options
The show options let you control the visibility of each entity. The Force Explorer does not draw vectors for entities that have been hidden in the Model Browser.
![](../../../images/figures/inspire/force_explorer_window.png)
Figure 2. Force Explorer
- Show Forces
- Show or hide all forces in the motion run.
- Show Torques
- Show or hide all torques in the motion run.
- Show Text
- Show or hide the numerical values associated with the forces and torques. Motion contacts do not show a numerical value unless you have selected the Sum Forces option under Contact Forces.
- Show Always on Top
- Always show the force or torque vectors drawn on top of the geometry.
- Show Implicit Joints
- Show or hide all forces and torque vectors associated with implicit joints.
- Use the entity buttons to toggle the visibility force/torques associated with specific motion entities. The number of buttons changes based on what types of motion entities are in the model, and can be toggled wile the analysis is being run.
- Keep in mind that showing a large number of vectors and text can slow down the animation playback speed. we recommend toggling off information you don't need to visualize.
- The entity button for joints is toggled off by default to minimize the number of vectors drawn.
- Force/torque vectors are not drawn for motors or actuators with a Controller Type of Soft Constraint.
- When reviewing motion results, force and torque vectors can be selected for plotting.
- You can dock and undock the Force Explorer.
Contact Forces
The Contact Forces section allows you to control the visibility of motion contact forces.
![](../../../images/figures/inspire/force_explorer_contacts.png)
Figure 3. Contact Forces
- Sum Forces
- This option converts several force vectors into an equivalent force/torque combination. When unchecked, the numerical value is not reported.
- Show Normal Forces
- Show or hide the contact normal force component.
- Show Tangential Forces
- Show or hide the contact friction force component.
- Show Planes
- Show or hide the planes drawn at the base of the normal vector arrow.
- Vector Density
- Use the slider to reduce the number of vectors drawn for the contact region. A value of 1 shows all of the vectors, while a value of 0 shows one.
- Show Output Steps Only
- Motion contact results typically have intermediate frames interspersed between the output steps for contact visualization. You can use this option to suppress the intermediate frames and show only the output steps. This is helpful when you want uniform time spacing between your playback output frames.
- Jump to Contact Event
- When animation playback is paused, you can jump to the first, previous, next, or last contact event. If you hold down the Previous or Next button, it will auto-repeat.
Advanced Options
The Advanced options allow you to scale motion contact forces and torques, and define whether to show action or reaction forces.
![](../../../images/figures/inspire/force_explorer_advanced.png)
- Scale Force
- Drag the slider to scale the force vector relative to the model.
- Scale Force Length
- Drag the slider to change the length of force vectors.
- Scale Force Radius
- Drag the slider to change the radius of force vectors.
- Scale Torque
- Drag the slider to scale the torque vector relative to the model.
- Action or Reaction
- Select whether to show action forces, reaction forces, or both.
