If you've previously run a motion analysis, use the Review Motion Results tool to open the Animation Toolbar and animate
the mechanism. You can also pick an object to plot.
Use the Analyze Motion tool to run and review the results of a motion
analysis.
Analyze Motion icon
Run Motion Analysis
Use the Quick Run and Run Settings tools to define and run a motion analysis.
Animate and Plot Motion Results
If you've previously run a motion analysis, use the Review Motion Results tool to open the Animation Toolbar and animate the mechanism. You can also pick an object to plot.
