OS-V: 0700 Twisted Cantilever Beam (Implicit Results)
MacNeal-Harder Test This is a twisted cantilever beam solved with solid and shell elements. A model is made with each element's type to investigate the effect of distorted elements with a high aspect ratio.
Figure 1. FE Model of the Beam with Boundary Conditions and Loadcases
Benchmark Model
Six types of elements are used for this problem. They are tria-shell, quad-shell, and hexa-solid elements, each with 1st and 2nd order. Two loading cases are used for each model; in-plane bending, transverse bending. For both load cases, unit loads are applied in a consistent fashion over all of the nodes at the tip of the beam.
| Load Type | Component | Value |
| In-plane bending | UY | 0.001754 |
| Transverse bending | UZ | 0.005424 |
Linear Static Analysis Results
| In-plane Bending | Transverse Bending | |
| QUAD4 | 0.988 | 0.992 |
| QUAD8 | 1.014 | 1.062 |
| TRI3 | 0.839 | 0.984 |
| TRI6 | 1.161 | 1.215 |
| HEX8 | 0.986 | 1.005 |
| HEX20 | 1.017 | 1.052 |
Model Files
The model files used in this problem include:
- /TBhex8.fem
- /TBhex20.fem
- /TBquad4.fem
- /TBquad8.fem
- /TBtri3.fem
- /TBtri6.fem
Reference
MacNeal, R.H., and Harder, R.L., A Proposed Standard Set of Problems to Test Finite Element Accuracy, Finite Elements in Analysis and Design, 1 (1985) 3-20.
