OS-E: 0850 V-Bracket using RADOPT
Demonstrates topology optimization of a V-bracket with RADOPT technique, using OptiStruct. RADOPT is Radioss optimization using OptiStruct. The equivalent static load method (ESLM) is used to perform the optimization run here.
Figure 1. FE Model
Model Files
The model files used in this example include:
- hook_opt_0001.rad
- hook_opt_0000.rad
- hook_opt.rad
Model Description
- FE Model
- Elements Types
- HEXA
- MAT1
- Young’s Modulus
- 2.1E5 MPA
- Poisson's Ratio
- 0.3
- Density
- 7.9E-9
