OS-T: 2005 Design Concept for a Structural C-Clip with Minimum Member Size Control
In this tutorial you will setup a topology optimization problem that applies the technique of minimum member size control on the elements of the model to achieve a discrete solution.
Performing topology optimizations early in the conceptual design stage results in the generation of a good baseline design and contributes to a shorter design cycle. One challenge with post-processing topology optimization results is that the results may have several intermediate density elements or checkerboard patterns which can be interpreted either as solid members or as a void. If these semi-dense elements are interpreted as thin members, the final design is harder to manufacture.
OptiStruct offers the minimum member size control method which provides some control over member size in the final topology designs by defining the least dimension required in the final design. It helps achieve a discrete solution by eliminating the intermediate density elements and checkerboard density pattern, resulting in a discrete and better-reinforced structure, which is easier to interpret and also easier to manufacture.
Launch HyperMesh and Set the OptiStruct User Profile
Import the Model
Apply Minimum Member Size Control Parameter
Minimum member size control will be applied to achieve a discrete solution.
Run the Optimization
The result files load automatically into HyperMesh and HyperView on completion of the run, so you can proceed directly to the post-processing step.
