OS-E: 0150 Large Displacement Analysis of Chassis
Demonstrates the use of 2D plate (shell) elements with large displacement analysis.
Figure 1. FE Model
Model Files
The model file used in this example includes:
SHELL_LGDISP.fem
Model Description
- Front torsional stiffness
- Rear torsional stiffness
- Vertical bending stiffness
Rail and Cross members modeled with shell elements, 7 are connected via rigid elements.
Displacements (translations and rotations), which are large enough to render small deformation theory invalid; therefore, the initial stiffness matrix is not suitable to represent the problem. This may result in either small or large (finite) strains. Large displacements are those that are greater than the characteristic dimension of the model (thickness of the beam plate or shell). This is always a nonlinear problem. A typical rule of thumb, if strains exceed 5%, always switch LGDISP=1.
- FE Model
- Element Types
- CQUAD4
- MAT1
- Young’s Modulus
- 2.1E5 MPA
- Poisson's Ratio
- 0.3
- Density
- 7.85E-9
- MATS1
- YIELD Point
- 350
Results
Figure 2. Stress Contour and Plastic Strain Plot
