OS-E: 0325 3D Rotor Dynamics Model
This example is about running a Frequency Response Analysis of a 3D rotor dynamics model using OptiStruct.
Figure 1. Model
Model Files
The model files used in this example include:
- rtr3dmodel.fem
- runrtrdyn.fem
Model Description
- Run a CMS analysis on the 3D rotor model to reduce it to a Superelement (DMIG). Use the file rtr3dmodel.fem. PARAM,COUPMASS,YES is used to get the accurate DMIG for gyroscopic matrix.
- Use the Superelement and attach to the 1D rotor model and run the Rotor Dynamics Analysis with the model file runrtrdyn.fem.
- FE Model
- Element Types
- CHEXA
- Material
- Linear Material
- MAT1
Results
Figure 2. Driving Point FRF in the X-Direction
