Small Deformation of a Cantilever Beam under Gravity and End Point Load
Model Description
Model location: <altair>\utility\mbd\nlfe\validationmanual\model2.mdl
This model consists of a straight beam fixed to the ground at one end and subject to a vertical load at the other end. The beam is also subjected to gravity as shown in Figure 1 below.
![](../../../images/solvers/nlfe_small_deformation_fig1.png)
Figure 1. A Beam of Fixed at One End and Subject to Self-weight and a Load at the Other End
- Vertical deformation of the end point of the beam mm
- Applied end force
- Beam length
- Young's modulus
- Moment of inertia about the axis normal to the page
- Beam density
- Acceleration due to gravity
- Beam cross section area
Multibody Model
The cantilever beam is modeled using 20 NLFE beam elements in MotionSolve. The cantilever beam is fixed to the ground by a fixed joint.
![](../../../images/solvers/nlfe_small_deformation_cantilever_beam.png)
Figure 2. The Cantilever Beam Modeled in MotionView
This model is simulated with an end time of 5 seconds, for a dynamic analysis. Under the end force, the beam is expected to deflect in the vertical direction by an amount predicted by the theoretical model.
- 5000 mm
- 50000 mm2
- 41.66 x 106 mm4
- 7.86 x 10-6 kg/mm3
- 2.1 x 105 N/mm2
- No gravity
- With gravity
The Z displacement of the last grid point will be used to determine the end point deflection. This is available as a standard output in the MRF output file.
Numerical Results
The multibody model described in the previous section is run for an end time of 5.0 seconds. The Z displacement of the last grid point is plotted below. The blue line depicts the displacement when gravity is included in the model and the red line depicts the displacement when gravity is turned off.
Figure 3. Z Displacement for the Endpoint Node
The plots above show that the displacement of the end node of the beam changed during the simulation due to the bending deformation:
DZ | g=9.81m/s2 | g=0 |
-43.9305 mm | -9.522 mm |
Conclusion
The NLFE model with 20 BEAM elements shows close agreement to the theoretical results for this case.
Euler-Bernoulli | Numerical | % error | |
DZ (gravity on) | -43.95 mm | -43.93 mm | 0.05 % |
DZ (gravity off) | -9.53 mm | -9.52 mm | 0.11 % |
The results presented use the default solver settings present in MotionView.
