Custom Statements
Custom statements allow advanced users to expand the set of MotionSolve model elements by adding new standard model element vocabulary. Custom statements can be mapped to one or more model elements.
Custom statements can be mapped to elements of the same type or of different types. You can choose the element name as well as the attribute names.
When a custom element has the same name as a pre-defined MotionSolve model element, the custom model element takes precedence. In other words, custom model elements override pre-defined model elements.
For instance, consider a PID controller:
Figure 1. A Block Diagram of a PID Controller
The PID controller calculation involves three separate parameters: proportional, integral, and derivative values:
  1. Proportional value determines the reaction to the current error and is represented by:(1) K [ u ]
  2. Integral value determines the reaction based on the sum of recent errors:(2) 1 s [ u ] = x 1
  3. Write this equation in another form:(3) x ˙ 1 = u
  4. Derivative value determines the reaction based on the rate at which the error has been changing, having two parts:(4) C [ u ] = x 3
  5. Alternatively:(5) x 3 C [ u ] = 0
  6. And:(6) s [ x 3 ] = x 2
  7. Alternatively:(7) x ˙ 3 x 2 = 0
  8. The weighted sum of these three actions is used to adjust the process via a control element, such as the position of a control valve:(8) x 1 + x 2 + K [ u ] = y
The proportional, integral, and derivative terms are summed to calculate the output of the PID controller.
Thus, you get the custom element (8) with three Control_Diffs (one explicit and two implicit) and one Reference_Variable.
Create a Custom Statement
  1. Edit the mapping file.
    An entry is made to the mapping file declaring the custom function as shown in the image below:
    Figure 2. Editing the Mapping File to Declare a Custom Function
    Figure 3.
    The general syntax for the CustomElement element is as follows:
    <CustomFunction
       SYMBOL              = "string"
      <Attribute
        ID                 = "integer"
        NAME               = "string"
        TYPE               = "string"
        DEFAULT            = "real"
    ... (to be repeated for each attribute)
      <Component
        ID                 = "integer"
        CTYPE              = "string"
    [In addition, all attributes needed to define the Component completely based on its type]
    ... (to be repeated for each component)
    Table 1. Children. ATTRIBUTE: Specifies the definition of a particular attribute of the custom element.
    Attribute Description
    ID Attribute identification number, (integer>0). This is a number that is unique among all attributes of the custom element.
    NAME Name of the attribute that needs to be used in the MotionSolve XML.
    TYPE Specifies the data type for the value of the attribute.
    DEFAULT Specifies the default value to be used for the attribute.
    Table 2. Children. COMPONENT - Specifies the definition of a particular component of the custom element.
    ID Component identification number, (integer>0). This is a number that is unique among all components of the custom element.
    CTYPE Specifies the type of the component. Supported component types include:
    Non-Usersub Cases
    • GRAPHICS
    • MARKER
    • PART
    • POINT_MASS
    • STRING
    Single Usersub Cases
    • GFOSUB
    • VFOSUB
    • VTOSUB
    • SFOSUB
    • FIESUB
    • CURSUB
    • SURSUB
    • UCOSUB
    • GCOSUB
    • MOTSUB
    • REQSUB
    • VARSUB
    • DIFSUB
    • SENSUB
    • SEVSUB
    • SPLINE_READ
    • GRASUB
    Multiple Usersub Cases
    • CNFSUB, CFFSUB [either one is good (and equivalent)]
    • COUSUB [maps to COUSUB/COUXX/COUXX2]
    • GSESUB
  2. Define the path to the mapping file.
    1. Modify the environment variable Variable name as MS_CUSTOM_MAPPING_FILE to point to the mapping file, as shown in the image below:
      Figure 4. Set the Environment Variable
  3. Create VARSUB and DIFSUB-like user-written subroutines and build a DLL as shown in the image below:
    Figure 5. User Defined Subroutine, DLL, and Corresponding XML Files
    Figure 6.
From this point forward, the VARSUB function name for the PID controller is VAR_PID and the DIFSUB function names are DIF_PID1, DIF_PID2, and DIF_PID3. These are the custom functions that can be used in models just like pre-defined MotionSolve functions. You can use them anywhere in a model as you would a standard, MotionSolve model element.
For instance, the element on the left in the image below is internally interpreted by MotionSolve into the set of elements shown on the right.
Figure 7. Internal and Custom Representations
MotionSolve internally interprets custom elements using a combination of standard elements, according to the instructions in the mapping file. Click <Save/> to check the resultant mapping.
