Set parent modules with CMS SE representation in H3D format to be used for analysis in lieu of child module representations
when rolled up, or use the child representations when rolled down.
To manage any of the modules shown in the Assembly Browser, right-click on a module and select Edit Representations. This opens the Edit Module tab, and the Representation sub-tab is shown.
Allows symmetric creation of LP Modules, Connections and dynamic LCS.
There are rules for automatic naming of newly created symmetric entities. You can break and
deactivate symmetry using the Break Symmetry and Deactivate Symmetry options available in
the context menu. Figure 1.
