vidIViewControl Translation
Moves the axes up, down, left, or right, based on the given string input.
hwIViewControl_handle Translation str
HyperWorks Tcl Modify
This command moves the video within the window, based upon an input string. This differs from Translate in that you input a string with a preset amount to move, rather than an input value to move.
- str
- The str, or string, is an input which tells the function which direction it should move. Each string moves the video one unit in each direction stated. The different string options include: “up”, "down", "left", "right", "upleft", "upright", "downleft", and "downright".
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetViewControlHandle vc;
vc Translation “downleft”;
If no string is input, an error message is displayed. If a string that is not one of the options is input, nothing will happen. Otherwise, it returns success (0) and the plot changes.
Keywords
- HyperWorks
- Tcl
- Video
- Modify
