txtITextEditor GetFontHandle
Gets a handle to the font.
txtITextEditor_handle GetFontHandle iFont
HyperWorks Tcl Query
- iFont
- The iFont handle.
Success (0) or an error code.
View new features for HyperWorks Desktop 2021.2.
Clears the text editor.
Redraws the text editor.
Evaluates the raw text.
Returns the background color.
Returns the evaluation state of text client text.
Returns the evaluated text.
Returns the foreground color.
Returns the name of the text file.
Returns the raw (unevaluated) text.
Loads the text from a file.
Refreshes all page areas with the text changes that have been made.
Saves the content of the text editor to a file.
Sets the background color.
Allows you to control the evaluation state of text client text.
Sets the foreground color.
Sets the raw (unevaulated) text.
