tblITableEditor GetFilledTableSizeRows
Returns the number of filled rows.
tblITableEditor_handle GetFilledTableSizeRows
HyperWorks Tcl Query
Returns the number of rows between the top and bottom row which contain cells with values.
The following cells are filled in a table:
The variable $filledNumberOfRows will be “5” (Row 5-9).
set t [hw::GetT]
set activetableHandle [hwi GetActiveClientHandle ch$t]
set filledNumberOfRows [$activetableHandle GetFilledTableSizeRows]
