poIVectorCtrl SetScaleMode
Sets the scale mode used to display vectors.
poIVectorCtrl_handle SetScaleMode name
HyperView Tcl Modify
This command sets the scale mode used to display vectors.
name
magnitude
Display vectors by their magnitude.
uniform
Display vectors using a uniform size.
Returns 0 if successful, otherwise an error code.
