poISystemCtrl GetLayer
Gets the current layer for the system review control.
sysctrl_handle GetLayer
HyperView Tcl Query
This command retrieves the current layer that is applied in the system review plot (for example - Ply 1, Ply 10001001, etc.). By default, this command returns the first layer.
hwi OpenStack
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
result_handle GetSystemCtrlHandle sysctrl_handle
set layer [sysctrl_handle GetLayer]
hwi CloseStack
Always returns a valid layer. If no results were attached, the system control handle is not retrievable, thus this command cannot be called.
