poISweepCtrl SetSelectionSet
Assigns a selection set to the axisymmetry controller.
poISweepCtrl_handle SetSelectionSet idstr
HyperView Tcl Modify
This command sets a selection set to the axisymmetry controller.
- idstr
- The string which fully defines the selection set. It is a locator string which may also be a pool ID string.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetSweepCtrlHandle sweep_handle
sweep_handle SetSelectionSet 5
hwi CloseStack
Returns an non-zero value if an error occurs.
