poISubcase GetDerivedSimulationList
Returns a list containing the labels of all the derived simulations.
subcase_handle GetDerivedSimulationList
HyperView Tcl Query
This command returns a list containing the labels of all the derived simulations
This command is similar to the GetDerivedSimulationLabel command, the only difference is that this command will return the labels of all the derived simulations.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
set scid [result_handle AddSubcase];
result_handle GetSubcaseHandle subcase_handle $scid
subcase_handle SetDerivedType “superposition”
subcase_handle AppendSimulation 3 0;
subcase_handle AppendSimulation 4 1;
set ndsimlist [subcase_handle GetDerivedSimulationList];
hwi CloseStack
None.
