poIStressLinearizationCtrl SetRunOption
Sets the run method be used.
poIStressLinearizationCtrl_handle SetRunOption method
HyperView Tcl Modify
This command sets the run method to be used. "Stress Linearization" is the default method.
- method
- Methods available are: "Extract Data", "Stress Linearization", and "Strain Linearization".
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_ctrl
result_ctrl GetStressLinearizationCtrlHandle stresslin_ctrl
stresslin_ctrl SetRunOption method
hwi CloseStack
None.
